06 scion TC wiring diagram 791xv
Covette03
Member - Posts: 36
Posted: April 12, 2006 at 7:26 PM / IP Logged
Can anyone give me the wiring diagram for a viper 791xv alarm/remote start on a 2006 scion tc sedan? Also what bypass will I need to put on the car in order to remote start (I'm looking for the bypass that you program ex. DEI555U or DEI555S)?
infinkc
Copper - Posts: 438
Posted: April 12, 2006 at 7:29 PM / IP Logged
12volts red (30A), white (25A)   +   ignition harness
Starter black   +   ignition harness
Second Starter green   +   ignition harness
Ignition blue   +   ignition harness
Second Ignition yellow   +   ignition harness
Third Ignition N/A
Accessory gray   +   ignition harness
Second Accessory N/A
Keysense black   -   ignition harness
Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Power Lock green to blue   -   driver kick, 20 pin plug, pin 15
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock purple to pink (double pulse)   -   driver kick, 20 pin plug, pin 14
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is purple to lt. green (-) in the passenger kick, 10 pin plug, pin 7.
Lock Motor blue to brown   5wi driver kick, gray 7 pin plug, pin 6
Unlock Motor pink to blue   5wi driver kick, gray 7 pin plug, pin 5
Parking Lights+ brown   +   top of fuse box, 30 pin plug, pin 29
Parking Lights- brown   -   headlight switch
Hazards orange   -   hazard light switch
Turn Signal(L) yellow   +   top of fuse box, 30 pin plug, pin 27
Turn Signal(R) green   +   top of fuse box, 30 pin plug, pin 28
Reverse Light pink   +   top of fuse box, 14 pin plug, pin 2
Door Trigger orange (D), blue (P)   -   top of fuse box
Notes: The driver door is orange in a 30 pin plug, pin 21. The passenger door is blue in a 16 pin plug, pin 14. Use both wires and diode isolate each.
Dome Supervision blue   -   L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin purple   -   top of fuse box, 30 pin plug, pin 7
Hood Pin N/A
Trunk/Hatch Release orange   -   driver kick, gry 12 pin plug, pin 12
Notes: Meter this wire while using the back door opener switch on the hatch.
The hatch release motor wire is lt. green to white in the driver kick, gray 12 pin plug, pin 6.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black   ac   data link conn. under dash, pin 9
Notes: The tach wire is also found at the ECM behind the glove box, top plug, pin 5.
Wait to start N/A
Brake Wire blue   +   brake pedal switch
Parking Brake black   -   parking brake switch
Horn Trigger white   -   horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
There are 10 types of people in the world, ones that understand binary and ones that dont.
Covette03
Member - Posts: 36
Posted: April 12, 2006 at 10:56 PM / IP Logged
Alright thanks a lot! that should be all that I need.
~Joe
