Multimeter shows 1.5 minimum?
dkeshish
Copper - Posts: 92
Posted: May 06, 2006 at 5:25 PM / IP Logged
Hi guys if you are familiar with my posts I have this huge grounding issue in my 2006 chrysler 300. for some apparent reason I cant get a good ground. I DONT KNOW WHY! if you know this vehicle the battery is in the trunk. I read somewhere that its not good to connect the amps ground to the bettery so I connected it to the wire that is from the battery to the car. So I check with my DMM from the car battery to that bolt and its at 1.5 I check elsewhere and there is nothing less than that. WHAT THE HECK? I have 2 amps and they arent connected. Please help.  am i checking the ground incorrectly?
I turn the multimeter on switch it to 200, not 2k, not 20k not 200k and connect both the + and - wires to check how calibrated the meter is. it reads .3
after that I connect the - lead to the - of the battery and the red goes anywhere i want to mount the ground....
Aruman
Silver - Posts: 363
Posted: May 06, 2006 at 7:06 PM / IP Logged
did you try different DMM?
Shaking The Neighborhood
dkeshish
Copper - Posts: 92
Posted: May 07, 2006 at 1:45 AM / IP Logged
Yes I bought a brand new one.
zhalverson
Copper - Posts: 180
Posted: May 07, 2006 at 1:56 AM / IP Logged
I'm assuming you have read the grounding sticky.  Sometimes the resistance of the actual vehicle can be high.  From what I understand the actual ground in a vehicle is the alternator body.  Since in your car the battery is grounded in the back the resistance between there and the alternator through the frame etc. can be high due to welds and other imperfections.  I think an option would be to run a power wire from your amps' grounding point or battery (whatever's easier) and connect that to the chassis where the alternator is grounded.  Someone correct me if I'm wrong.
geepherder
Platinum - Posts: 3,668
Posted: May 07, 2006 at 8:47 AM / IP Logged
There's nothing wrong with grounding to the battery if it's close.  I've done that on occasion.  Usually amps go in the back and since the battery is usually up front it makes more sense to ground to the frame/body.  Otherwise you'd have to long ground wire to run, with possibly slightly more of a voltage drop than just grounding to the vehicle chassis.
sparkie
Platinum - Posts: 2,061
Posted: May 07, 2006 at 11:34 AM / IP Logged
Are you checking the ground with the meter set on Ohms? This is not how to check the wire unless the entire circuit is dead. If there is any power to the circuit, you will get a wrong reading. To check for a good ground for your amps, set your meter to a DC voltage scale. Put one probe on the ground connection at one amp and the other probe to a known good ground. Scrape away the paint of the body next to where you intend to ground the amp. If you get a reading of 0.2 volts or less, then you have a good ground.
sparky
dkeshish
Copper - Posts: 92
Posted: May 07, 2006 at 6:34 PM / IP Logged
Sparkie do I disconnect the amp? both power and ground?
geepherder
Posted: May 09, 2006 at 6:03 AM / IP Logged
Do not disconnect the amp to perform this test.  Sparkie is correct- the voltage drop test is a better test to perform- it can identify weak grounds when under load.
