power anttena line as amp remote on
mech3
Copper - Posts: 76
Posted: May 23, 2006 at 8:02 PM / IP Logged
I'm not sure if this is a stupid question or not (if it is I apoligize), but can the remote power anttena line from the back of the head unit be used as a secondary remote trun on for a second amp?
Thanks for any info
spookiestylez
Silver - Posts: 531
Posted: May 23, 2006 at 10:02 PM / IP Logged
when the radio is on is only when the pwr antenna wire is getting 12v....If you dont have a blue/white wire off the deck its just usally a blue wire (pwr antenna color) or you could always use the switched power (red on aftermarket deck harness).GL
sS
geepherder
Platinum - Posts: 3,668
Posted: May 24, 2006 at 8:28 PM / IP Logged
Typically (not always), the power antenna lead loses power when you switch to a source other than radio (cd, etc.).  That would cause you to lose sound on other sources.
mech3
Copper - Posts: 76
Posted: May 24, 2006 at 9:45 PM / IP Logged
what typically  is used for remote amp turn on in a dual amp situation. I have heard that hooking 2 amps to one remote turn on line is not good to do. I have done it before and it worked, but with lesser power amps.
xtremej
Gold - Posts: 1,440
Posted: May 25, 2006 at 8:12 AM / IP Logged
You can fire up 2 amps with 1 remote turn, I haven't  had a problem with it. If you are concerened you could use a relay to trigger them both but its not necessary.
