dome light supervision
rock1
Copper - Posts: 120
Posted: May 29, 2006 at 9:55 PM / IP Logged
How do you connect the dome light supervision on a bulldog 62I there is no information in the manual. I was told it may need a relay do I have to cut any wires for this?
mrcllusb
Copper - Posts: 489
Posted: May 30, 2006 at 4:42 AM / IP Logged
On you 621 there is a violet wire that is your domelight supervision wire.To hook it up you need to wire it like this.
87-ground
86-violet wire from alarm
85-fused 12v
30-negative door trigger wire
make sure you install a 1 amp diode between 30 and the door trigger wire
"ole blake"
