rookie installer
el terror
Member - Posts: 33
Posted: June 07, 2006 at 9:29 PM / IP Logged
i wanted to ask you experienced guys, i did my first alarm instalation last week and i just wanted to know if i did it right i got  the 12v positive from the fuses and with the door locks what i did was that since the wire coming from the alarm to give the signal to open or close didnt have enough power to move the switches i put relays. was that a good way to do it?
el terror
Member - Posts: 33
Posted: June 07, 2006 at 9:42 PM / IP Logged
the car was a 98 ford crown victoria
djfearny2
Silver - Posts: 810
Posted: June 07, 2006 at 10:09 PM / IP Logged
the relays are fine as long as they are connected right. as far as getting power from fuses., thats ok by the normal possition to get power and ignition is the key cylinder wires.
Jon
Installer/Help Technician
---coral springs florida---
el terror
Member - Posts: 33
Posted: June 07, 2006 at 10:52 PM / IP Logged
thanks man,
now i have a friend that wants me to install a remote start in his 2003 chevy 1500 that has keyless entry. i have never installed a remote start is there any were i can get info on how to install it? well im preaty sure i can install it the only thing is what do i do about the key less entery?
el terror
Member - Posts: 33
Posted: June 07, 2006 at 11:09 PM / IP Logged
is it the same on all newer cars and trucks with keyless entry?
kaezoo
Copper - Posts: 125
Posted: June 08, 2006 at 6:50 AM / IP Logged
The 03+ GM trucks are NOT your typical keyless entry; they use a data bus to control the locks and the lock modules are found in the individual doors. Get a data-based bypass module like a Directed 457G to make the install MUCH easier.
djfearny2
Silver - Posts: 810
Posted: June 08, 2006 at 7:03 AM / IP Logged
that truck is very easy for the people who have done them before. however for a new person it is hard because there multiple modules involved that have to be used. either a 457g(controls door locks) 555l (controls Security key feature) or this is a unit by dei that controls both in one instead of two seperate i just forgot what it is. I think it is a 456gw or a 457gw
Jon
cntrylvr79
Silver - Posts: 582
Posted: June 08, 2006 at 8:47 AM / IP Logged
Close, but you got a couple of the part number backwards.  The 456g controls only door locks, and the 457g(or 457gw) controls the locks and the security bypass.
Cause I'm So white and nerdy...
First Class Certi-fried installer
el terror
Member - Posts: 33
Posted: June 08, 2006 at 8:00 PM / IP Logged
thank you guys
