disabling remote start
flyimages
Posted: June 21, 2006 at 3:50 PM / IP Logged
I'm in the process of installing the Crimestopper CS-2011DP remote start/keyless entry alarm, but i do not want to enable the remote start.  Should i follow the instructions step by step (pages 4-14) and just skip any wires that has to do with the remote start?  Which wires would not be necessary to connect?
Here's the wires i plan on skipping:
Wht/Red - Tach
Wht - Brake
Grn
Orn
Orn/Blk
& anything to do with the parking brake or clutch.
I've included the pdf manual link below:
Car: 2001 Toyota Celica 6spd. link to my car specific diagram: https://www.the12volt.com/installbay/forum_posts.asp?tid=6902
Alarm: Crimestopper CS-2011DP (pages 4-14)
http://www.crimestopper.com/techweb/InstructionBooks/ComboSystem/cs2011_2016dp_30option_ins.pdf
Chris Luongo
Platinum - Posts: 3,746
Posted: June 21, 2006 at 4:51 PM / IP Logged
There must be some type of toggle switch to enable/disable the remote starter.
Leave the toggle switch disconnected altogether, or tie it to a hidden location and leave it in the off position. Either way, it'll then be impossible for the remote start to come on.
If there is no toggle switch, then there is probably at least a neutral-safety wire.........leave that disconnected as well.
