flip down on 00 sierra
oscarnl86
Copper - Posts: 84
Posted: July 17, 2006 at 10:21 AM / IP Logged
hey guys new here,  heres my question my cusin has a 00 gmc sierra extended cab and he wanted to put a 12" or 15" flip doen on the roof my question is. is that going to be too much weight for the roof? do i have to make a braket or something by that nature?
any help will be apreciated
thanx in advance
djfearny2
Silver - Posts: 810
Posted: July 17, 2006 at 11:53 AM / IP Logged
if you pull out the back light if it has one you will see that you can attached small screws with a piece of wood above headliner to support the monitor. hope this helps.
ps you should be able to slide wood through the side i dont cut the headliner unless 100% have to and i encourage the same for others. as far as others go there lazy
Jon
Installer/Help Technician
---coral springs florida---
shaip99
Copper - Posts: 112
Posted: July 19, 2006 at 2:12 AM / IP Logged
i would suggest you drop part of the headliner so you can slide some wood ( i say to drop part of the head liner so you dont crease the headliner hard to fix and expensive to replace)i usually use 1/4 mdf not to heavy but it will hold the overhead in place. You should cut the wood about and inch or two bigger then the unit and you will be able to screw into that hope that helps
"Computer games don't affect kids, I mean if Pac Man affected us as kids, we'd
all run around in a darkened room munching pills and listening to repetitive
music."-Kristian Wilson, Nintendo Inc.
