1991 lincoln towncar, remote start
armani1318
Posted: July 23, 2006 at 12:24 PM / IP Logged
I'm having problems with my friends remote start on a 1991 lincoln towncar. When the car it's remote started it shuts off right away and then it remote starts again by itself and it keeps doing the same thing until it is powered down by either the remote or by unpuging the fuses. We are using an add on remote starter system. This system comes with a Smart sense so that means we didn't use the tach wire. Can anyone please help. Thank you and I appreciate it.
josh1979
Silver - Posts: 320
Posted: July 23, 2006 at 1:16 PM / IP Logged
if all ign and start wires are correct than the only thing left is something to tell the R. start unit that the car is running that would be tach, so if the unit has a tach wire hook it up as per the directions on the remote start. i only use smart sence or voltage sence when the car has no tach wire that can be accessed because smart /voltage sence is a hit or miss if it going to work. usulay what the unit is looking for is a change in voltage when the alternator kickes in. so if you do have to use smart  sence and is not working move the 12V batt. line from the remote start to the cars batt.
12volts brown or lt. green   +  ign. harness
Starter dk.blue/orange   +  ign. harness
Second Starter
Ignition BROWN / pink   +  ign. harness
Second Ignition pink/black   +  ign. harness
Third Ignition
Accessory BLACK/ lt. green   +  ign. harness
Second Accessory
Keysense
Power Lock pink / YELLOW  +,- drivers kick panel
Notes: Non-keyless cars are normally (+) pulse with relays in the passenger kick panel, but at least one car was found to be 5 wire. Check the back of the driver side lock switch if in doubt. Keyless cars are (-) pulse on the same wires.
Power Unlock pink/green  +,- drivers kick panel
Notes: Non-keyless cars are normally (+) pulse with relays in the passenger kick panel, but at least one car was found to be 5 wire. Check the back of the drivers side lock switch if in doubt. Keyless cars are (-) pulse on the same wires.
Lock Motor
Unlock Motor
Parking Lights+ brown    drivers kick panel
Notes: Factory alarm module located in lower passenger side kick panel with keyless entry module. BLACK/ orange (doors), dk. blue (horn - ), and WHITE/ purple (light flash +) are all at alarm mod.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger blk/blue   +  pass. kick panel
Dome Supervision
Trunk/Hatch Pin tan/green   -  at factory alarm
Hood Pin common with trunk
Trunk/Hatch Release purple / YELLOW   +  switch or keyless mod.
Power Sliding Door
Factory Alarm Arm arms on lock
Factory Alarm Disarm dk. GREEN/ purple   -  kick or alarm module
Disarm No Unlock
Tachometer gray/orange   AC EDIS dr. shock tower
Notes: EDIS module locate at driver side shock tower. Gray/orange wire at one end of 12 pin plug.
Wait to start
Brake Wire lt. green   +  at brake pedal switch
Parking Brake
Horn Trigger dk. blue   -  at steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
1991 lincoln towncar, remote start - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
No
Type:
N/A
Part #: N/A
bring back the rotary phone so i dont have to press 1 to proceed in english
armani1318
Posted: July 23, 2006 at 1:44 PM / IP Logged
Thank you and It does make sense as to what you're saying. I am gonna use the tach wire then. Thanks alot.
