Wiring Toyota Camry 89
elmonomalo
Member - Posts: 8
Posted: August 11, 2006 at 6:29 PM / IP Logged
Hello,
I am new to wiring car electronics but have a good background with wiring regular electrical appliances. I need help wiring a new ECD12 stereo system into the factory stereo slot(Toyota 86120-06020). I noticed when the instructions that came with the stereo said to use the existing wiring harness, the two harnesses were incompatible. I then decided to cut the factory harness and now i have the ECD12 harness ready to be wired.
I will include pictures if someone would be kind to help a man in dire need Wiring Toyota Camry 89 - Last Post -- posted image.
factory molex connectors...
new stereo molex connectors...
wires from new stereo harness...
I will attempt to explain my delay now...
According to the model...
1989 Toyota 4-Runner Camry Wiring Diagram
The new stereo instructions say...
1. Dark Blue Wire - The dark blue wire can be used to remotely activate an automatic antenna or an external amplifier.
The model wiring diagram from this site says "Right Front" How would I connect the dark blue wire to my antenna? Is the antenna a specific wire color?
2. Red Wire - Connect to 12V+ accessory.
Would I connect to the Gray or Blue / YELLOW wire?
3. Black Wire - Connect to metal part of the dash drilling a hole if necessary.
The wiring diagram states the Brown wire is the ground. Would I drill the hole or would i just connect the black and brown wires?
4. Connect to 12V+ battery terminal
5. Antenna Connector- Connect the antenna plug from the existing antenna cable.
Does this mean I don't use the Dark blue wire? They really confused me at this point.
Sorry for a very lengthy post. I appreciate any help you guys can give me.
Thank You,
Aaron
elmonomalo
Member - Posts: 8
Posted: August 11, 2006 at 6:44 PM / IP Logged
Oh, how dumb of me Wiring Toyota Camry 89 - Last Post -- posted image..
I thought cutting the factory harness out was bad. I also noticed I posted the wrong wiring diagram...
89 Toyota Camry
The harnesses had a different number of wires. old-6 to new-4 and old-10 to new-8. I had no idea i could convert it.
I think i can rewire it no problem but the 5 questions i asked need to be answered since i'm a total noob.Wiring Toyota Camry 89 - Last Post -- posted image.
elmonomalo
Member - Posts: 8
Posted: August 11, 2006 at 7:12 PM / IP Logged
Yeah, I know what you mean. I can do just about anything with computer hardware and when people ask dumb questions i feel the same way.
I actually found a diagram but I'm confused
Here's what i asked... may be a little off because i posted wrong diagram, but it's the basic gist.
Thanks for the help.Wiring Toyota Camry 89 - Last Post -- posted image.
elmonomalo
Member - Posts: 8
Posted: August 11, 2006 at 7:23 PM / IP Logged
Yes, your last post helped me out alot. I have one more question though. The manual suggested drilling a hole and adding a screw for the ground. Should I do as they suggested or will connecting the two wires suffice?
Once again,
Thanks.
elmonomalo
Member - Posts: 8
Posted: August 12, 2006 at 4:15 PM / IP Logged
Ok, after painfully realizing how dumb cutting the harness out was I'd have to say it was pretty easy to install the head unit.Wiring Toyota Camry 89 - Last Post -- posted image.
Thanks for the help, my camry sounds so much better.
