DEI XHF plus antenna
mobilecustoms
Silver - Posts: 397
Posted: August 12, 2006 at 10:03 PM / IP Logged
what is the range on the DEI XHF plus antenna? I just got two of them and they seem to be pretty good. it also has a SAW filter- what does that do?
ringojam
Copper - Posts: 215
Posted: August 12, 2006 at 10:44 PM / IP Logged
Those antennas are used mainly on clifford alarms.What does the saw filter look likeDEI XHF plus antenna - Last Post -- posted image.
Jamaica home of the worlds fastest man.
mobilecustoms
Silver - Posts: 397
Posted: August 13, 2006 at 8:18 AM / IP Logged
it looks like just a regular antenna. it looks like the hf plus nothing special.
gus1
Gold - Posts: 1,013
Posted: August 14, 2006 at 4:27 PM / IP Logged
A saw filter is a specific type of RF bandpass filter...... it doesn't look like anything special. It won't have Husquavarna painted on it or anything...... maybe 3 more components on the PCB of the antenna.
Gus
mobilecustoms
Silver - Posts: 397
Posted: August 14, 2006 at 4:55 PM / IP Logged
ok so what is the range that im looking at to be? will it work through buildings that have a problem with the range of the hx antenna?
kgerry
Platinum - Posts: 3,455
Posted: August 15, 2006 at 9:53 AM / IP Logged
range will run about 1500 ft consistently.... will be better at building penetration than an HF Plus by far..... but still drop off when going through walls like any other unit would....
this is an old antenna... i would opt for the XR Plus... which should give you better range and stability....
dont get wrapped up in distance ratings.....i've seen "1000 ft range" antennas do twice that and i've also seen "2000 ft range" antennas do half that.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
mobilecustoms
Silver - Posts: 397
Posted: August 15, 2006 at 1:29 PM / IP Logged
i already have this antenna the guy i bought it from said xr plus was not as good as xhf plus. so im stuck now. but it seems to be pretty good.
mobilecustoms
Silver - Posts: 397
Posted: August 15, 2006 at 1:33 PM / IP Logged
also what is the range of the 791xv antenna- the responder?
kgerry
Posted: August 15, 2006 at 1:49 PM / IP Logged
being that it's an XHF Plus antenna...       asked and answered....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
mobilecustoms
Silver - Posts: 397
Posted: August 15, 2006 at 5:19 PM / IP Logged
the responder is really an xhf plus antenna? i had no idea. thanks for the info.
