My head unit worked but now it doesn't
chancelyng
Posted: August 13, 2006 at 12:49 PM / IP Logged
I was installing a two piece head unit (a dvd/cd player and a lcd flip out monitor). I didnt protect hte ignition/12v/ground wires while installing so the copper was showing. Both units were working until either the ignition/12v came in contact with the ground wire. It blew a fuse underneath my steering wheel not on the new units. I replaced it, but now the cd/dvd player wont work....the lcd monitor still does. So i took it out. Connected a 12v battery charger to the dvd/cd player and it turned right on...
Anyone know how i can fix this problem?
DYohn
Platinum - Posts: 10,741
Posted: August 13, 2006 at 1:50 PM / IP Logged
Look for another blown fuse.
chancelyng
Posted: August 13, 2006 at 2:35 PM / IP Logged
i tried that but all the fuses are good
chancelyng
Posted: August 13, 2006 at 2:50 PM / IP Logged
so i tried again this time i connected the ignition and 12v wired together and it works... is it safe to keep it likke that? and also is that wierd?
DYohn
Posted: August 13, 2006 at 3:34 PM / IP Logged
I am willing to bet they are not.  Did you check all fuses in all fuse bozes, including under the hood, and did you meter them to make sure they are good?
As far as connecting the IGN and Batt leads together, the down side is the radio will not turn off with the key and it may drain your battery.
