03 Eclipse 2W900FMR unlock issue
Raymond4646
Copper - Posts: 121
Posted: August 14, 2006 at 12:54 PM / IP Logged
The vehicle is an 03 Elcipse GTS with factory keyless/transponder.  The problem is the passengers side door will not unlock, but will lock with compustar.  If I remove the lock/unlock output from the compustar to car both doors will still lock and drivers side will lock, so the factory alarm arm/disarm outputs from the compustar is triggering this.  Anyhelp would be appreciated.  Thanks!
Raymond4646
Copper - Posts: 121
Posted: August 14, 2006 at 2:44 PM / IP Logged
Never mind guys, I figured it out.  It was a programing issue.  Thanks for looking.
shaggy12volt
Copper - Posts: 164
Posted: August 14, 2006 at 2:46 PM / IP Logged
you might want to try to send a singal wire to the disarm defeat wire in the car diode isalate it from the unlock out put. Blue/black wire pin 17 28pin plug below fuses
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
shaggy12volt
Copper - Posts: 164
Posted: August 14, 2006 at 2:48 PM / IP Logged
glad to see you got it
The Shagmaster
Raymond4646
Copper - Posts: 121
Posted: August 14, 2006 at 3:38 PM / IP Logged
  Thanks for the help man!!!!
