05 Chry Pt Cruiser Conv. Rem. Start Wires
dbone69usc
Posted: August 20, 2006 at 6:07 PM / IP Logged
If anyone has the wiring diagram for a 2005 Chrysler PT Cruiser Convertible (Dream Cruiser)..if that Matters i Dont Know.. I Would be very appreciative for your help.
                 Thanks,Dbone69
Dbone69
josh1979
Silver - Posts: 320
Posted: August 21, 2006 at 6:52 PM / IP Logged
CHRYSLER / PT CRUISER / 2005 / Remote Start
12volts pink/black (40A), red (30A)  +  ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition dk. blue  +  ignition harness
Second Ignition lt. grn/wht (only w/AutoStick) +  igntion harness
Third Ignition N/A
Accessory BLACK/ orange  +  ignition harness
Second Accessory BLACK/ white  +  ignition harness
Keysense lt. blue  -  ignition harness
Power Lock WHITE/ dk. green  -  driver kick or RKE module, pin 10
Notes: Lock/arm is negative trigger thru a 3000 ohm resistor. Unlock/disarm is negative trigger thru a 7200 ohm resistor. MUST use relays. Unlock requires a double pulse.
The RKE (Remote Keyless Entry) module is in the top center of the dash.
On vehicles without factory alarm, can also use 1000 ohm resistor for lock, and 249 ohm resistor for unlock.
Power Unlock same as power lock wire
Lock Motor ORANGE / black or ORANGE / purple  5wi driver kick or RKE module, pin 4
Notes: The RKE (Remote Keyless Entry) module is in the top center of the dash.
Unlock Motor dk. blue or pink/black  5wi driver kick or RKE module, pin 5
Parking Lights+ BLACK / YELLOW  +  switch or RKE module, pin 2
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) lt. green (F), dk. grn/red (R) +  turn signal switch
Turn Signal(R) tan (F), BROWN / red (R)  +  turn signal switch
Reverse Light PURPLE / black  +  driver kick, harness to rear
Door Trigger see notes  -  each kick or RKE module, pins 25, 7
Notes: The driver door is tan/dk. blue or tan. The passenger door(s) is tan/red or dk. blue/orange. Use both wires and diode isolate each.
Dome Supervision yellow  -  passenger kick, harness to rear
Trunk/Hatch Pin tan/black  -  driver kick or RKE module, pin 24
Hood Pin BROWN / tan (export model only)  -  pin switch or RKE module, pin 23
Trunk/Hatch Release BROWN / lt. blue  -  RKE module, pin 14
Notes: On the convertibles, this wire is also found at the switch in the glovebox. On the 4 doors, this wire is also found in the driver kick, harness to the rear.
Can also use lt. GREEN/ black (+) in the driver kick or at the RKE module, pin 16.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power unlock wire
Tachometer NOT dk. GREEN/ orange  ac  ignition coil or any fuel injector
Wait to start N/A
Brake Wire WHITE/ tan  +  brake pedal switch or driver kick
Parking Brake WHITE/ black  -  parking brake switch or pass. kick
Horn Trigger BLACK/ red  -  switch or RKE module, pin 18
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
05 Chry Pt Cruiser Conv. Rem. Start Wires - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Sentry Key
Part #: 555CW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface
Required:
Yes
Type:
Multiplex
Part #: 456LW
Notes:
Smart Starter Kill Relays:Relay Type:
Starter Relay
Engine compartment fusebox, Driver side
Part #: 6404A
bring back the rotary phone so i dont have to press 1 to proceed in english
