1995 Dodge Intrepid
colguin
Member - Posts: 7
Posted: January 20, 2003 at 8:31 PM / IP Logged
Hi, trying to install an alarm/starter and having troubles finding the correct wiring. Does anyone have the wiring information on a 1995 dodge intrepid?
Chris O.
brianh
Silver - Posts: 518
Posted: January 21, 2003 at 1:01 PM / IP Logged
Here is the colors for your vehicle:
|              12V|pink/black,red (20A)|+  |ignition harness            |
|          STARTER|yellow/gold dots    |+  |ignition harness            |
|         IGNITION|dk. blue/gold dots  |+  |ignition harness            |
|  SECOND IGNITION|RED / wht/gold dots   |+  |ignition harness            |
|   THIRD IGNITION|*3                  |   |                            |
|        ACCESSORY|BLACK/ orange        |+  |ignition harness            |
|       POWER LOCK|ORANGE / white *1     |+  |wht plug back of fuse panel |
|     POWER UNLOCK|pink/purple *1      |+  |wht plug back of fuse panel |
| PARKING LIGHTS +|BLACK / YELLOW        |   |driver kick panel           |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|green               |+  |headlight switch            |
|     DOOR TRIGGER|tan & tan/red *2    |-  |driver kick panel           |
|  TRUNK/HATCH PIN|BROWN / black         |-  |driver kick panel           |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|BLACK/ white         |+  |at switch                   |
|  FCTRY ALARM ARM|lock                |   |                            |
|FCTRY ALRM DISARM|lt.GREEN/ orange 20ga|-  |either kick                 |
|       TACHOMETER|red, white, or black|   |at coil pack                |
|       BRAKE WIRE|white               |+  |at brake switch             |
|     HORN TRIGGER|BLACK/ red           |-  |relay in fuse panel         |
|           WIPERS|pink                |+  |3 wire plug near wiper motor|
|  LF WINDOW UP/DN|lt.blu/gld - wht/gld|A  |in driver door              |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |in driver door or dkp       |
|  LR WINDOW UP/DN|blu/wht - RED / blk   |A  |in driver door or dkp       |
|  RR WINDOW UP/DN|gry/blk - grn/wht   |A  |in driver door or dkp       |
Notes:
*1 Also find same colors in harness to right of glove box by passenger kick panel.  *2 Tan gets drivers door, tan/red gets pass. doors. Tap both wires and diode isolate.  *3 The SRS (air bag) warning light may come on after remote started, after the key is inserted and the remote start shut down with the brake. If this happens, find an 18ga (NOT 12ga) RED / white in the ignition harness. Power it as an Ign 3 with an additional relay.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
