99 volvo c70 remote start
almeida79
Member - Posts: 47
Posted: October 11, 2006 at 6:34 AM / IP Logged
Does any one have the wiring info for a remote starter for a 99 volvo c70 convertible? Is it the same as the s70? Thank's in advance
Jay
gcorrea
Silver - Posts: 436
Posted: October 11, 2006 at 10:28 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - VOLVO / C70 / 1999 / Remote Start
[PRINT THIS PAGE]
12volts      red (10A)       +       ignition harness
Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12v.
Starter      yellow/white       +       ignition harness
Second Starter
Ignition      GREEN/ YELLOW       +       ignition harness
Second Ignition      blue / YELLOW       +       ignition harness
Third Ignition
Accessory      yellow/purple       5wi      ignition harness
Second Accessory
Keysense      yellow (required)       +       ignition harness
Power Lock      yellow/gray       -       keyless module
Notes: The keyless module is located above the hood release. It is a black box with 2 green plugs.
Power Unlock      gray/red       -       keyless module
Notes: Requires a double pulse for unlock.
Lock Motor      yellow       5wi      driver kick, door harness
Unlock Motor      blue/brown       5wi      driver kick, door harness
Parking Lights+      white       +       headlight switch
Notes: If you have factory daytime running lights, and you use the white at the switch for parking lights, the headlights will flash as well. The solution is to wire the white at the switch as a 5 wire system. Also, there are 2 white wires at the switch. They go to the same pin. treat them like one wire.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      pink/black       -       keyless module
Notes: To avoid the dome light delay, there are 2 separate door trigger wires at the keyless module. They are: LF WHITE/ black, RF yellow/brown. Both wires are negative trigger and must be diode isolated from each other.
Dome Supervision      comes on with unlock
Trunk/Hatch Pin      blue/brown       -       keyless module
Hood Pin      yellow/black       -       keyless module
Trunk/Hatch Release      yellow/white       -       keyless module
Power Sliding Door
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      disarms with unlock
Disarm No Unlock      single pulse unlock wire
Tachometer      NOT red, black, or yellow       ac       any ignition coil
Wait to start
Brake Wire      yellow       +       brake pedal switch
Parking Brake
Horn Trigger      yellow/red       -       keyless module
Notes: This triggers the alarm horn, the vehicle horns only work with the ignition on.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
gcorrea
almeida79
Member - Posts: 47
Posted: October 12, 2006 at 9:22 PM / IP Logged
Thank's a lot
Jay
