Transponder 01 Focus
Ron_toolman
Member - Posts: 32
Posted: November 22, 2006 at 8:48 AM / IP Logged
Hello all ...... just installed remote starter in 01-Focus, everything worked fine with the key in the ignition so the remote could read the key, but when I install the spare key in the coil transponder and rap the antenna around the key barrel no start. Checked wiring to transponder and have +12 volts on red, Neg to output from remote and of course the coil around the key . I've been looking for a transponder that doesn't need the spare key so it can be programed and I won't need to spend 50 bucks for a spare (3rd)key, then that will be it. Any suggestions wouild be appreciated. A supplier that sells keyless transponders for ford would be great, anyone else have a problem like this ? ....
Thanks Ron .....
Big Dog
Gold - Posts: 1,265
Posted: November 22, 2006 at 9:44 AM / IP Logged
There are a lot of data solutions including 1100F from DEI.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Hymer
Silver - Posts: 695
Posted: November 22, 2006 at 9:52 AM / IP Logged
XK04 from bypasskits.com the coil should work, but it takes a lot of playing around sometimes....data works MUCH better../
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
ers1121
Copper - Posts: 110
Posted: November 22, 2006 at 7:38 PM / IP Logged
The Xpresskits work best if the remote system has the data port for the connection, bypasskit.com has the vehicle selection wizzard so you get the right one. But they cost almost as much as the spare key.
Ed
