2002 Lexus SC430 Remote Start
skandalous
Member - Posts: 15
Posted: November 25, 2006 at 9:05 PM / IP Logged
Is there a imobilizer bypass kit that will work with the Lexus SC430?  I recently picked one up and the car came with no keys. I had a master and valet key made as well as the ECU reflashed to accept the new keys but forsomereason i cannot get the car to recognize the new set of keys. I wanted a remote start anyway so maybe this is a better solution than sending it to the dealer for key programming.  Any help wil be appreciated.
Garth
Member - Posts: 11
Posted: November 25, 2006 at 10:55 PM / IP Logged
PKT2 - bypasskits.com you need 1 key to program the bypass module (cannot be the valet key)
skandalous
Member - Posts: 15
Posted: November 25, 2006 at 11:28 PM / IP Logged
My car currently wont start because the key programming instructions the locksmith gave me dont seem to work. Will the bypass module still work eventhough the master and valet keys arent currently programmed to the car? The keys are cut and will open/close the doors and turn the ignition. The car wont start though...2002 Lexus SC430 Remote Start - Last Post -- posted image.
captainzab
Silver - Posts: 606
Posted: November 26, 2006 at 10:12 AM / IP Logged
You wont be able to program the bypass without a valid key programmed to your car.
You dont have valid key at all?
All you need is a preprogrammed key to programm your new keys to the ECU
Try it again
Note: You Always Dont Get What You Pay For.
skandalous
Member - Posts: 15
Posted: November 26, 2006 at 2:18 PM / IP Logged
Does anyone know where I can obtain master key programming instructions for the Lexus SC430? Thanks
skandalous
Member - Posts: 15
Posted: November 26, 2006 at 3:10 PM / IP Logged
Is there a bypass module that will eliminate the need to have a pre-programmed key? Since I have been thinking of an aftermarket alarm system anyway.
Garth
Member - Posts: 11
Posted: November 27, 2006 at 12:44 AM / IP Logged
no - otherwise all of the thieves would use them, and Lexus couldn't advertise that they have an anti-theft system, now, right?
Garth Shostal
Ground Pounders - Automotive Security
Est. 1998
