Bw 10000 immobiliser wiring
rowdyjim
Posted: December 03, 2006 at 5:14 AM / IP Logged
Need help with wiring immobiliser !! Please!!
mauri197
Copper - Posts: 80
Posted: December 03, 2006 at 10:09 AM / IP Logged
it would help if you said what typy of car and system you are using
rowdyjim
Posted: December 03, 2006 at 6:15 PM / IP Logged
alarm is bw 10000 ( black widow )- Black wired -installed into a 95 honda civic. I have everything installed central locking door switches etc... I have only the the immobiliser side of things to go. the alarm module has two sets of two cables labeled imob. both sets and both cables are black.
The manual says: This is the relay normal open 30a dry contact circuits. Cut and connect to an appropriate isolating Circuit. switched 12 volts, max 30amps.
Do i just cut the ignition wire and join meaning it has a relay in the unit
Both sets of wires have no voltage and dont ground?
Hope this makes any sense Bw 10000 immobiliser wiring - Last Post -- posted image.
