'07 Lincoln MKZ info?
wiretapper
Copper - Posts: 166
Posted: December 05, 2006 at 6:35 PM / IP Logged
I have to do a remote starter on an '07 Lincoln MKZ. Anyone have info on it yet?
Crimestopper lists no info as of yet. Any info from Direct techs?
Twelvoltz
Platinum - Posts: 2,384
Posted: December 05, 2006 at 8:07 PM / IP Logged
DEI does not have anything listed yet.
Audiovox lists:
     #509853: 2007 LINCOLN MKZ 4DR SEDAN WITH 3.5L ENGINE AND PREMIUM AUDIO SYSTEM
Remote Start
     WIRE          COLOR          POLARITY          LOCATION
     Battery          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLUE          (+)          IGNITION SWITCH HARNESS
     Accessory 1          GRAY / YELLOW          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLACK/ BLUE          (+)          IGNITION SWITCH HARNESS
     Key Sense          YELLOW          (+)          IGNITION SWITCH HARNESS
     Parking Lights          BLACK/ LIGHT GREEN          (-)          AT VEHICLE LIGHT SWITCH
     Brake Lights          RED / LIGHT GREEN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          WHITE/ YELLOW          (+)          IN HARNESS AT LIGHT HOUSING
     Horn          DARK BLUE          (-)          AT SMART JUNCTION BOX IN FRONT OF CENTER CONSOLE
               PLUG B - PIN #7
     Security
     All Door Trigger          GREEN/ ORANGE          (-)          IN HARNESS IN DRIVERS KICKPANEL
               PLUG E - PIN #7
     Domelight Super          BLACK/ LIGHT BLUE          (+)          AT SMART JUNCTION BOX IN FRONT OF CENTER CONSOLE
               PLUG E - PIN #7
     LF Latch          LIGHT GREEN/ BLACK          (-)          AT SMART JUNCTION BOX IN FRONT OF CENTER CONSOLE
               PLUG C - PIN #20
     RF Latch          YELLOW/LIGHT GREEN          (-)          AT SMART JUNCTION BOX IN FRONT OF CENTER CONSOLE
               PLUG C - PIN #22
     LR Latch          VIOLET/LIGHT GREEN          (-)          AT SMART JUNCTION BOX IN FRONT OF CENTER CONSOLE
               PLUG C - PIN #7
     RR Latch          RED          (-)          AT SMART JUNCTION BOX IN FRONT OF CENTER CONSOLE
               PLUG C - PIN #6
     Trunk Trigger          BROWN          (-)          IN HARNESS IN DRIVERS KICKPANEL
               PLUG C - PIN #5
     Hood Trigger          GRAY/RED          (-)          AT PIN SWITCH UNDER HOOD
               PLUG A - PIN #6
     Alarm Disarm          WHITE/ BLUE          (+)          IGNITION SWITCH HARNESS
     Doorlocks/Windows
     Power Unlock          VIOLET/GRAY          (-)          IN HARNESS FROM DOOR IN EITHER KICKPANEL
               PULSE THIS WIRE TWICE TO UNLOCK ALL DOORS IN SOME MODELS.
     PowerLock          GRAY / YELLOW          (-)          IN HARNESS FROM DOOR IN EITHER KICKPANEL
               PIN #3
     Driver Mtr Unlock          YELLOW          (REV)          AT MOTOR IN DOOR
     Driver Mtr Lock          PINK/BLACK          (REV)          AT MOTOR IN DOOR
     Pas Mtr Unlock          PINK/WHITE          (REV)          AT MOTOR IN DOOR
     Pas Mtr Lock          PINK/BLACK          (REV)          AT MOTOR IN DOOR
     LF Window Up          WHITE/ BLACK          (+)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     LF Window Dn          YELLOW          (+)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Up          RED / WHITE          (+)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Dn          YELLOW/RED          (+)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     LR Window Up          YELLOW/LIGHT BLUE          (+)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     LR Window Dn          GRAY/BLACK          (+)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     RR Window Up          RED / BLACK          (+)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
     RR Window Dn          YELLOW/BLACK          (+)          AT MASTER WINDOW SWITCH IN DRIVERS DOOR
wiretapper
Copper - Posts: 166
Posted: December 06, 2006 at 4:16 AM / IP Logged
Thanks Twelvolts!
NowYaKnow
Gold - Posts: 1,217
Posted: December 07, 2006 at 8:37 PM / IP Logged
wiretapper
Copper - Posts: 166
Posted: December 07, 2006 at 10:06 PM / IP Logged
Excellent. Thanks!
