Ungo sr6000
deciphe
Posted: January 25, 2007 at 10:39 AM / IP Logged
I have a Ungo Clarion sr6000 in a 97 honda prelude and for some reason it will drain the battery overnight?
It has a dei transponder module, sunroof trunk and window operation everything seems to work correctly except overnight it will drain?
thanks for any info.
cpgoose
Gold - Posts: 1,098
Posted: January 25, 2007 at 12:37 PM / IP Logged
Does this happen every night?
Why are you assuming it's the alarm that's doing it? Just curious.
Do you have access to the alarm? Maybe you can pull the power harness off of it for a night or two and see if that makes a difference. That might help narrow it down.
deciphe
Posted: January 25, 2007 at 4:40 PM / IP Logged
This happens every night i have the alam plugged in. If i unplug the smaller connector 12 pin not the main relay harness it disables alarm and will never die.
Plug it it and Poof overnight its dead. When it is plugged in everything seems to work fine except for my problem. Only thing i noticed that i had to dissable the door trigger 2nd check via bit writer, or it would give a error chip. I thought this was because of the supervised dome was lit to long.  It has a fadeout dome light.
thanks for any help
