2006 sentra drv prio locks
p/t installer
Member - Posts: 29
Posted: January 29, 2007 at 8:15 PM / IP Logged
i've recenly installed a viper 160xvl in a 2006 nissan sentra, and hooked up just about everything on the car to the viper,  and now the customer wants to know if there was a way to have kept the drivers priority unlock like the factory remote did.  all of the wiring diagrams i can obtain does not show the wires for drivers priority,  how do i go about this when all of the drivers priority door locks i've done have only been when i program a data bus interface.  i know ill need relays, but how do i wire it in?  by the way the car does not have a factory alarm but it did have a module above the gas pedal that have door pin wires and horn wires and door lock/unlock wires where i did alot of attaching to.  and i threw  an xpresskit xk03 or xk05 which ever one it was to bypass the key and that works like a dream.
       thanks in advance for your time.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 30, 2007 at 8:27 AM / IP Logged
Dk. blue/red at thye keyless module next to the column...it's reverse polarity. Use the unlock trigger from the alarm to do this relay wired for the drivers door only, then use the 2nd, unlock output to do the rest of the doors. If your unit does NOT have a second unlock out put....your in a tough way....
Big Dog
Gold - Posts: 1,265
Posted: January 30, 2007 at 8:38 AM / IP Logged
There is no second unlock so use the AUX channel (2).
Prepare your future. It wasn't the lack of stones that killed the stone age.
