03 accord over cranking
97gss
Copper - Posts: 235
Posted: February 01, 2007 at 6:39 PM / IP Logged
2003 accord 2.4l vtec.  Got the blue wire on passenger side of console for tach.  Went to white plug on the left with the small letter E on the bottom right(white plug on the left of the pcm).  Installing an Ultrastart 1270.  Will learn tach, but will over crank for about half a second.  Any suggestions?  I've attempted to do low idle learn, tach learn with the car in gear, set the crank time to a max of 3 seconds, and tried using the "overcrank" adjustment.  I've attempted all of these several times over the last hour.  Is is possible/better to catch tach at the plug?  Seems like the car has a COP setup.
green6767
Copper - Posts: 209
Posted: February 01, 2007 at 7:10 PM / IP Logged
i've also run into this problem on other hondas. Sometimes it overcranks, sometimes it doesn't. Seems to happen with the Odyssey's. I get the tach at the same spot as you mentioned aswell. I do many of these cars, but I'm installing Astro. Again, its on a case by case basis.
Shaun, we are the same height, that is neat!
12V Installation Technician for Honda, Dodge, Chrysler, Toyota and Jeep.
KarTuneMan
Platinum - Posts: 7,056
Posted: February 01, 2007 at 11:49 PM / IP Logged
hey green6767, empty your "inbox" in your PM section....I tried to send one to ya....it's FULL!
green6767
Copper - Posts: 209
Posted: February 02, 2007 at 9:21 AM / IP Logged
Oops. i didn't realize you could only have a storage of 20 maximum. Sorry bout that. I know how annoying it can be. They are all gone now.
