2002 ext cab z71 silverado
seejay6969
Posted: February 13, 2007 at 12:21 AM / IP Logged
My factory radio has a cd player built in to the deck and a tape player which is seperate.
There was an option on my truck to get a CD changer. I did not purchase the CD changer. There is a module I want to install that uses a connection to the cd changer cable. Does my truck have this cable or connection on the deck even though I didn't order the CD changer?
bellsracer
Silver - Posts: 703
Posted: February 19, 2007 at 1:43 AM / IP Logged
I believe there is a connection to it there... If you open up and look at the back of the radio, there should be a plug back there with either a cap in it or just an open harness plug hole. You module should plug into it. Now depending on your module, most have a bypass on it so you don't loose your tape player, but there are some that will not give you the t-harness for that.
swerve
Copper - Posts: 149
Posted: February 19, 2007 at 6:07 PM / IP Logged
are you trying to do an ipod connection or an aux in connection to your radio?
git yer swerve on!
seejay6969
Posted: February 20, 2007 at 7:59 AM / IP Logged
IPOD, I was looking at the peripheral electronics ipod2car module. I wasn't aware that there were any others available? If there are please clue me in. I would like to look at them. Thank you very much for your reply.
swerve
Copper - Posts: 149
Posted: February 20, 2007 at 3:51 PM / IP Logged
pac makes one that is an aux in, it gives you two 3.5 mm inputs for whatever you want to hook up. it hooks up through the xm port on the back of the deck, xm still works. the ipod2car plugs into the changer port on the back. all the wires for the ipod2car come in the box, you just gotta set the dip switches to the right setting for your truck. ive used both and havent had any problems with either one. just depends on what you want to do.
git yer swerve on!
seejay6969
Posted: February 24, 2007 at 8:04 AM / IP Logged
Thank you very much.2002 ext cab z71 silverado - Last Post -- posted image.
seejay6969
Posted: March 02, 2007 at 5:06 PM / IP Logged
ipod2car site says that I will lose functionality of my CD player and Tape deck. Is that true? Is this only when I am using the ipod are period. When it says to disable the device, does this mean just unplug them or is more complicated than that. Also with the other 3.5mm module, it says the source must be playing at all times? My stereo does not have XM radio?
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
