2007 toyota tundra, alarm/remote start
delexatek
Member - Posts: 8
Posted: February 15, 2007 at 7:52 PM / IP Logged
does anyone have the vehicle wiring for an 07 Tundra? also if the 5.7L is any different?
'the alarm drained the gas tank!!!'-KARR TEK-
draasch
Gold - Posts: 2,172
Posted: February 16, 2007 at 7:06 AM / IP Logged
Here is what I have. Check each wire with a meter.
Make:   Toyota
Model: Tundra
Year:    2005-06
This Database Was Last Updated On:    10/20/2006
Index #: 7595
Alarm
Constant 12 volts WHITE OR WHITE/ RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter GREEN/ BLACK (M/TRANS) IGNITION SWITCH HARNESS *
Dome Light WHITE/ BLUE (-) DRIVER KICK PANEL
Trunk Pin Switch NONE
Parking Lamp GREEN (+) DRIVER KICK PANEL
Power Lock WHITE/ GREEN DRIVER KICK PANEL ** #209
Power Unlock RED / YELLOW DRIVER KICK PANEL
* Starter Wire Is BLACK/ WHITE In Vehicles With Auto/Trans. ** Child Safety Wire Is RED / BLUE. #209- See Child Safety Door Lock Circuit Diagram
Accessories
Window Up D\ LIGHT GREEN P\ RED / BLACK AT MAIN #211
Window Down R/ BLUE / YELLOW S/ RED / WHITE SWITCH *
Ign Key Warn PINK/BLACK (-) 2 PIN CONN AT STEERING COLUMN HARNESS
Trunk Release NONE
OEM Horn GREEN/ RED (-) STEERING COLUMN HARNESS
Headlights GREEN/ YELLOW (-) AT HEADLIGHT SWITCH
OEM Alarm Arm WHITE/ GREEN (-)
OEM Alarm Disarm BLUE/RED (-) DRIVER KICK PANEL
* Access Cab: Rear Window GREEN/ BLACK (UP), RED / BLUE (DOWN) At Switch #211 #211- See Reversal Rest At Ground Window Circuit Diagram OEM Hood Pin-None OEM Horn- BLACK At Horn Behind Grill, In Front Of Radiator
Remote Start
Tach Signal BLUE/WHITE AT ECM BEHIND GLOVE BOX (8 CYL) *
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS
Ignition #3 NONE
Accessory BLUE/RED IGNITION SWITCH HARNESS
Neutral Safety NON GROUNDING TYPE
Brake Light GREEN / WHITE (+) AT SWITCH ABOVE PEDAL OR IN DKP
Reverse Light RED / BLACK (+) DRIVER KICK PANEL @ BACK UP RELAY
Rear Window Defrost NONE
*Can Also Be Found At Back Of Instrument Cluster. 6 Cylinder TACH Wire Is BLACK Located In 12 Pin Conn At Rear of Driver Junction Block Or One Of The Coil Wires At Igniter;( BLU/BLK, RED / BLK, LT GRN) Behind Air Filter Box.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
KarTuneMan
Platinum - Posts: 7,056
Posted: February 16, 2007 at 8:02 AM / IP Logged
The 07 is a brand new breed.
Mike M2
Platinum - Posts: 2,652
Posted: February 16, 2007 at 5:40 PM / IP Logged
Whole new truck, haven't domne one yet but i have one on the shedule next week....
Mike M2
Tech Manager
CS Dealer Services
DJJoeJ2000
Posted: March 26, 2007 at 4:20 PM / IP Logged
any update on teh 5.7l 2007 tundra?
profuse007
Gold - Posts: 2,015
Posted: March 26, 2007 at 8:39 PM / IP Logged
2007 TOYOTA TUNDRA QUAD CAB
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          WHITE          (+)          IGNITION SWITCH HARNESS
     Ignition 1          LIGHT GREEN          (+)          IGNITION SWITCH HARNESS
     Starter 1          DARK GREEN          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          ORANGE          (-)          AT UNDER DASH BULB
     Parking Lights          ORANGE          (-)          AT COLUMN
     Convenience
     Headlights-Lo          GREEN/ YELLOW          (-)          AT VEHICLE LIGHT SWITCH
     Wipers-Lo          BLUE/BLACK          (-)          AT VEHICLE WIPER MOTOR
     Remote Start
     Ignition 2          BLACK          (+)          IGNITION SWITCH HARNESS
     Accessory 1          GRAY          (+)          IGNITION SWITCH HARNESS
     Tachometer          UNCOMMON COIL OR INJECTOR
     Speed Sense          GREEN/ ORANGE          (AC)          AT MODULE BEHIND GLOVEBOX
     Brake Lights          ORANGE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          RED / BLACK          (+)          IN HARNESS IN DRIVERS KICKPANEL
     Horn          ORANGE          (-)          AT COLUMN
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          RED          (-)          IN HARNESS IN DRIVERS KICKPANEL
     PowerLock          WHITE          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Driver Mtr Unlock          BLUE/WHITE          (+)          IN HARNESS IN DRIVERS KICKPANEL
     Driver Mtr Lock          BLACK / YELLOW          (+)          IN HARNESS IN DRIVERS KICKPANEL
Houston,TX
aligator
Posted: March 30, 2007 at 10:53 PM / IP Logged
this vehicle is equipt with a transponder sytem you will need a third key2007 toyota tundra, alarm/remote start - Last Post -- posted image.
the king
KarTuneMan
Posted: March 31, 2007 at 12:25 AM / IP Logged
Just got the tech info on the Astrochart....there are "no key required" bypass modules available for this VERY cool truck.
hessdawg
Member - Posts: 16
Posted: April 02, 2007 at 12:16 PM / IP Logged
did one a week or 2 ago just make sure you zip tie the wires with some extra lenth to the column because it moves up and down and in and out. i just used a 555u and key and it worked perfectly
hessdawg out
vitrox
Copper - Posts: 96
Posted: April 02, 2007 at 12:52 PM / IP Logged
disarm/arm are pink and lt blue in drivers kick, they also control the locks.
