make intermittent wipers moreintermitte
tankd0g
Member - Posts: 21
Posted: February 20, 2007 at 9:07 AM / IP Logged
On the slowest setting my wipers have always been too fast, sweeping the windshield about twice as often as would be ideal in a light mist, has anyone done a hack to change the speed of them or make them variable?  I was thinking something along the lines of a dimmer switch under the dash to fine tune it but I'm not sure how these things are wired.
make intermittent wipers moreintermitte - Last Post -- posted image.
profuse007
Gold - Posts: 2,015
Posted: February 20, 2007 at 8:01 PM / IP Logged
if you got a toyota, check on a higher model of your vehicle w/ variable intermittence wiper switch and swap it out. might be an easier method.
Houston,TX
redpeppers
Silver - Posts: 483
Posted: February 20, 2007 at 10:47 PM / IP Logged
This is prolly a topic that should be posted into the relay section of the forum maybe you can find more help there.
Where theres is a wire there's a way.
tankd0g
Member - Posts: 21
Posted: February 21, 2007 at 8:57 AM / IP Logged
I suppose since the one in my Celica is what I want I could try and fit a Celica switch stock in there.  I'll have to try it out.
