2006 pontiac solstice alarm info
dankerr
Posted: February 24, 2007 at 5:41 PM / IP Logged
hey has anyone installed an alarm on one of these yet? if someone could post a wiring diagram that would be great. thanks
lsondubz
Copper - Posts: 193
Posted: February 24, 2007 at 6:42 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - PONTIAC / SOLSTICE / 2006 / Remote Start
[PRINT THIS PAGE]
12volts RED / black (50A)  +  BCM, C3, pin D1
Notes: The BCM (Body Control Module) is part of the fuse/relay box below the glove box. It has the following connectors: C1-72 pin gray plug, C2-72 pin gray plug, C3-41 pin red plug, and C4-68 pin lt. gray plug.
Starter yellow (not for remote start)  -  ECM, blue plug, pin 56
Notes: The ECM (Engine Control Module) is in the driver side rear corner of the engine compartment.
There is a white wire and a WHITE/ black wire in the ignition harness, or the BCM, C2, pins 56 and 62, that perform starter, second ignition, and key sense functions. No information at this time, if it is necessary to interface with these wires in addition to the PASS-key III+.
Second Starter N/A
Ignition yellow  +  ign harn or BCM, C4, pin D3
Second Ignition see starter wire notes
Third Ignition N/A
Accessory brown  +  ign harn or BCM, C4, pin C8
Second Accessory N/A
Keysense see starter wire notes
Power Lock white  -  driver kick or BCM, C1, pin 7
Notes: Lock is a straight negative trigger. Unlock is negative trigger thru a 1500 ohm resistor. MUST use relays.
Power Unlock same as power lock wire
Lock Motor gray  5wi driver kick or BCM, C3, pin A4 or A5
Unlock Motor tan  5wi driver kick or BCM, C3, pin B1
Parking Lights+ brown  +  driver kick or BCM, C3, pin A7
Parking Lights- BROWN / white  -  switch or BCM, C2, pin 5
Hazards white  -  switch or BCM, C2, pin 9
Turn Signal(L) lt. blue (F), yellow (R)  +  BCM, C1, pin 35 and C3, pin A9
Turn Signal(R) dk. blue (F), dk. green (R)  +  BCM, C1, pin 17 and C3, pin A12
Reverse Light lt. green  +  kick panel, harness to rear
Door Trigger gray/black (D), tan/white (P)  -  each kick or BCM, C1, pins 22 and 19
Notes: Use both wires and diode isolate each.
Dome Supervision gray  -  BCM, C3, pin A10
Trunk/Hatch Pin ORANGE / black  -  BCM, C1, pin 55
Hood Pin N/A
Trunk/Hatch Release tan  -  switch or BCM, C2, pin 10
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Passkey
Tachometer NOT pink/black or pink  ac  any fuel injector
Wait to start N/A
Brake Wire lt. blue  +  passenger kick or BCM, C1, pin 53
Parking Brake lt. blue  -  switch or BCM, C1, pin 14
Horn Trigger tan  -  switch or BCM, C2, pin 14
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2006 pontiac solstice alarm info - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III+
Part #: OM-GMC-6
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays: Not Available
dankerr
Posted: February 28, 2007 at 11:43 AM / IP Logged
thanks
