06 impala factory remote start
CutDog504
Silver - Posts: 643
Posted: March 28, 2007 at 11:12 PM / IP Logged
My brother just bought a 2006 impala and it has the factory remote start. He says the range is crap and he would also like a 2 way remote. My question is, is there any way to trigger the factory remote start with a module or something? I'll be installing a 2 way remote start/alarm, probably an autopage 1000rs, So can I use this to trigger the factory remote start some kind of way, or will I have to just hook up all the ign and start wiring?
Chris Luongo
Platinum - Posts: 3,746
Posted: March 29, 2007 at 6:41 AM / IP Logged
www.bypasskit.com
You can buy from them a kit with a module, antenna, and remotes.........operates the factory remote start, but with better range.
I think they have a 2-way option as well, but I'm not sure.
Astroflex also makes a similar piece.
Platinum - Posts: 12,488
Posted: March 29, 2007 at 8:44 AM / IP Logged
I agree with Chris, we are selling the new Chevy add-on modules that will give you longer range, retain most every option that the factory remotes have and also bypass the Passlock system and integrate into the OEM alarm system. Two ways systems are available and one way remotes as well.
xtremej
Gold - Posts: 1,440
Posted: March 29, 2007 at 10:41 AM / IP Logged
Jeff are you using the tx557 remote from trilogix?   The 2 way model is the trx72n, lcd dsplay.
Posted: March 30, 2007 at 8:50 AM / IP Logged
TRX722, TX557 or TX447 all work with the XL201 module.
CutDog504
Silver - Posts: 643
Posted: April 02, 2007 at 9:30 PM / IP Logged
Ok, I saw the ones at bypaskit.com . So basically I have to upgrade the factory alarm with those modules and remotes right? Is there any way I can use an aftermarket alarm with one of those modules so I can still add extra sensors and have all the aux output channels? Or do I HAVE to use the trilogix remotes with the trilogix remote start module?
CutDog504
Silver - Posts: 643
Posted: April 07, 2007 at 8:56 PM / IP Logged
Does anybody know?
