2007 silverado wire colors?
stevet
Member - Posts: 36
Posted: March 30, 2007 at 10:09 PM / IP Logged
I need to know the colored wires for 12v+ switched 12v+ and starter wires at the ignition harness, please help.
Securitydog1@verizon.net
mikvot
Gold - Posts: 1,043
Posted: March 30, 2007 at 10:20 PM / IP Logged
ign......pink@ ign harness or bcm. lt/green plug pin 14
12v RED / white at ignition harness(2 amp)
Here is the starter setup...http://directechs.com/techtips/pdfs/resources/security/directed_techtips/1605.pdf
For starter kill, use yellow/black (+) at the ECM, black 73 pin plug, pin 52. The ECM (Engine Control Module) is on the driver side fender, behind the headlight.
2007 silverado wire colors? - Last Post -- posted image.
CHEVROLET, SILVERADO, 2007, 12volts
For high current 12V, use RED / black (60A) and RED / black (60A) at the fuse box, black 40 pin plug, pins F1 and E3, or go to the battery.
stevet
Member - Posts: 36
Posted: March 31, 2007 at 11:58 PM / IP Logged
Thank you very much I apprediate it!
