aftermarket hu, 98 jeep zj w/infinity
litint
Posted: April 05, 2007 at 9:42 PM / IP Logged
I go to install my aftermarket head unit and i get everything hardwired and sound comes out and everything, when i turn the volume, all the guages and lights flicker and sometimes the headunit says protect. There are 2 wires that were seperate from the 2 harnesses in their own harness (2 wires) they are purple and WHITE/ black... where do they go? also some wires were also questionable.. infinity amp wire (which is it?) power antenna wire, power continued wire...has anyone installed an aftermarket head unit into a 98 ZJ with the infinity system? does anybody have the ACTUALLY CORRECT WIRING DIAGRAM? installdr.com is completely wrong, and no other websites have it. do i need an adapter such as this?:https://installer.com/cars/jeep.html (part CHYAH) does ANYONE know whything about this?? I had a professioal here who couldnt figure out the problem we had it all up and running. please help me i need this installed by tomorrow.
1998 Jeep ZJ Limited
Kenwood HU (Help me (infinity system woes))
2-12" Type R's
Kicker 1440 Watt Amp
KarTuneMan
Platinum - Posts: 7,056
Posted: April 05, 2007 at 11:20 PM / IP Logged
I hope this doesn't sound TOO stupid, but......whats a Jeep ZJ ?
KarTuneMan
Posted: April 05, 2007 at 11:22 PM / IP Logged
+12V DC Battery(Constant)RED / white  20 15 amp Junction block behind left side of dash
Switched AccessoryRED / gray  10 amp Junction block behind left side of dash
Ground Black
Illumination Orange Also dark blue/red
Left Front + Dark green Line level output
Left Front - BROWN / red Line level output
Right Front + Violet / YELLOW Line level output; changes to violet at the amplifier.
Right Front - Dark blue Line level output
Left Rear + BROWN / yellow Line level output
Left Rear - BROWN / lt.blue Line level output
Right Rear + Dk.blue/white Line level output
Right Rear - Dk.blue/orange Line level output
aftermarket hu, 98 jeep zj w/infinity - Last Post -- posted image. AMPLIFIER OUTPUTS
Wire FunctionColorNoteFuse #SizeLocation
12V DC BatteryViolet Amplifier pins C2-2 & 8 20 amp Junction block behind left side of dash
Left Front Mid + Lt.GREEN/ red
Left Front Mid - Lt.GREEN/ black
Right Front Mid + Lt.blue/red
Right Front Mid - Lt.blue/dk.green Changing to light blue/black
Left Rear Mid + WHITE/ red
Left Rear Mid - WHITE/ black
Right Rear Mid + Tan/red
Right Rear Mid - Tan/black
aftermarket hu, 98 jeep zj w/infinity - Last Post -- posted image. AT SPEAKERS
Left Front Mid + Dark green
Left Front Mid - BROWN / red
Left Front Tweeter + Lt.GREEN/ red Dash speaker
Left Front Tweeter - Lt.GREEN/ black Dash speaker
Right Front Mid + Violet
Right Front Mid - Dk.blue/red
Right Front Tweeter + Lt.blue/red
Right Front Tweeter - Lt.blue/black
Right Rear Mid + Dk.blue/white
Right Rear Mid - Dk.blue/orange
rudydapimp
Copper - Posts: 390
Posted: April 07, 2007 at 7:09 AM / IP Logged
Jeep Cherokee
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
