95 civic, viper 791
jose23
Member - Posts: 24
Posted: April 28, 2007 at 7:35 PM / IP Logged
No problem. The way you had it wired up, the vehicle's battery power (which is a 12v OUTPUT) was feeding back into the 520T's OUTPUT (so you had 12v going into both ends of the 520T, lol). Luckily you caught it in time and didn't fry the 520T module or it's backup battery.
-Jose
lilspeedy626
Member - Posts: 19
Posted: April 29, 2007 at 12:52 PM / IP Logged
I wanna install the Horn to my alarm, Any directions?  I have a 95 civic DX
pitoaudiovisual
Copper - Posts: 388
Posted: April 29, 2007 at 2:58 PM / IP Logged
the horn on a 95 civic is negative a blue/ green wire on the steering to the left .. most alarms run on positive horn so you might have to place a relay to reverse the polarity.. 85 wire from alarm pos , 86 negative, 87 negative and 30 to  blue / green of the car
Confidence is the key to any project!!
lilspeedy626
Member - Posts: 19
Posted: April 30, 2007 at 9:41 PM / IP Logged
Hello guys,  How can I install my hood pin to trigger my alarm.  I have a viper 791, I connect the gray wire from module to the swithc but nothing happend.  Any ideas.
Heres the switch
http://www.directechs.com/guides/manuals/ig/viper/N564V_6-03.pdf
Heres the Manual
lilspeedy626
Member - Posts: 19
Posted: May 12, 2007 at 3:51 PM / IP Logged
I wanna install a second siren on my viper alarm. on the 2nd siren i connect to chasiss ground and then I tap into the 1st siren power connector.  Is that correct,  will both sirens still get the same amout of power, loudensss.
enice
Silver - Posts: 857
Posted: May 12, 2007 at 6:48 PM / IP Logged
It should be ok.  If you dont  like the sound then you can use a relay for it.
lilspeedy626
Member - Posts: 19
Posted: May 15, 2007 at 1:09 PM / IP Logged
Hello For some reason my viper 791 alarm stop flashing the parking lights when i activate/deactive my alarm, please help me.
