03 trailblazer alarm
may03lt
Copper - Posts: 55
Posted: April 30, 2007 at 6:47 PM / IP Logged
Hey guys, I want to install a Viper 3201V in my 2003 Trailblazer LT.
I was told I would need a GMDLBP module and a GM-9 T-harness.
Is this info right?
Thanks!
KarTuneMan
Platinum - Posts: 7,056
Posted: April 30, 2007 at 10:17 PM / IP Logged
The T harnes is NOT neccesary, it simply makes the install easier..... The bypass module IS needed. This will REALLY help ease the install. Read the manual on this piece....it does a ton of features.
may03lt
Copper - Posts: 55
Posted: May 01, 2007 at 7:10 PM / IP Logged
Thanks man!
may03lt
Copper - Posts: 55
Posted: July 01, 2007 at 3:30 PM / IP Logged
Do I need door triggers from all 4 doors?
2003 Trailblazer LT
2007 Envoy SLT
fkelsey
Copper - Posts: 94
Posted: July 02, 2007 at 9:19 AM / IP Logged
Not if you buy the bypass piece it does it for you.
may03lt
Copper - Posts: 55
Posted: July 02, 2007 at 5:05 PM / IP Logged
the wiring diagram I have for the tb says there are seperate door trigger wires.
2003 Trailblazer LT
2007 Envoy SLT
KarTuneMan
Posted: July 04, 2007 at 10:51 AM / IP Logged
You will connect the door trigger input on the alarm, to the door trigger wire on the bypass....this will (the bypass) give the alarm the trigger signal.
may03lt
Copper - Posts: 55
Posted: July 04, 2007 at 10:56 AM / IP Logged
thanks im in the midst of the install now so well see how it goes
thanks bro!
2003 Trailblazer LT
2007 Envoy SLT
may03lt
Copper - Posts: 55
Posted: July 04, 2007 at 7:53 PM / IP Logged
KarTuneMan you are the man! Worked like a champ! Thank you SO much for taking the time to reply!
2003 Trailblazer LT
2007 Envoy SLT
