06 charger w/ chdl7 pk2 lock input
itzme
Member - Posts: 27
Posted: May 13, 2007 at 4:06 AM / IP Logged
Hello all, I had a quick (and probably stupid) question regarding installing a Viper 5900 on my 06 Dodge Charger using a Peripheral CHDL7-PK2 Bypass unit.
The bypass has a lock and unlock input which both require a neg. pulse. However, the Viper 5900 lock wires reverse polarity, ie. one wire is (-)Lock/(+)Unlock, and the other is (+)lock/(-)unlock.
My question is, will that positive pulse damage the Bypass unit? If so, do I just diode isolate the wire? Thank you all for your help.
Twelvoltz
Platinum - Posts: 2,384
Posted: May 13, 2007 at 9:00 AM / IP Logged
No it will not harm the bypass no need for diodes.
