2002 celica gt alarm?
illintentionz
Member - Posts: 8
Posted: May 16, 2007 at 12:32 PM / IP Logged
i need some help i have a 2002 celica gt an i need to know which wires are which to install my new alarm system with remote start. any help would be appriciated
lsondubz
Copper - Posts: 193
Posted: May 16, 2007 at 2:36 PM / IP Logged
Did you look in the vehicle wiring diagrams or do a SEARCH?? Anyway;
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / CELICA / 2002 / Remote Start
[PRINT THIS PAGE]
12volts blk/red & white   +  ignition harness
Starter BLACK/ white   +  ignition harness
Second Starter
Ignition BLACK/ orange   +  ignition harness
Notes: When doing remote start, this wire must be isolated from the keyswitch with the ignition relay. See direct fax document #1077.
Second Ignition blue/red   +  ignition harness
Notes: There are 2 blue/red wires in the ignition harness. The correct ignition wire is the heavier gauge one and it has 1 silver hash mark. The incorrect wire has 2 silver hash marks.
Third Ignition
Accessory gray   +  ignition harness
Second Accessory
Keysense
Power Lock brown   -  passenger kick or BCM
Notes: The BCM is located just to the right side of the radio. Remove the radio to access.
Power Unlock yellow/black   -  passenger kick or BCM
Lock Motor blue/white    driver kick or BCM
Unlock Motor blue    driver kick or BCM
Parking Lights+ use the (-) wire
Parking Lights- lt. green    steering column
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger RED / white   -  drivers kick
Notes: To avoid dome light delay, use RED / yellow at the driver door pin for the driver door and red at the passenger door pin for the passenger door. Isolate each door trigger with diodes.
Dome Supervision RED / white   -  driver kick
Trunk/Hatch Pin lt. green   -  trunk light or BCM
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer BROWN / white    rear of instrument cluster
Wait to start
Brake Wire GREEN / WHITE   +  brake switch
Parking Brake
Horn Trigger blue/black   -  steering column or BCM
Memory Seat 1
Memory Seat 2
Memory Seat 3
2002 celica gt alarm? - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
No
Type:
N/A
illintentionz
Member - Posts: 8
Posted: May 16, 2007 at 5:08 PM / IP Logged
sorry i did but i couldn't find it. thanks for helpn me out though. i appriciate it.
illintentionz
Member - Posts: 8
Posted: May 16, 2007 at 5:16 PM / IP Logged
but what does it mean when it says see direct fax document #1077
