wiring/box setup
silens.intro
Posted: May 25, 2007 at 6:06 PM / IP Logged
I'm running 2 12" Alpine E-Types in a sealed box (w=30.5in x h=15in x d=10.5in) powered by a MA Audio M700XE amp.
I was wondering if this setup would be appropriate:
https://img209.imageshack.us/img209/2624/wiringdiagramsh5.gif
Also, would you recommend any other setup besides that?
I also plan on sealing the box with Silicone Caulk and Pollyfill (1/2 lb. per cubic ft.) Would this also be appropriate for this setup? And if I do Pollyfill the box would you recommend loose or the sheets (wouldn't the loose stuff fly around inside via vibrations regardless of no airflow?)
Thanks!
-Silens.Intro
silens.intro
Posted: May 25, 2007 at 6:08 PM / IP Logged
(broken) Embedded image above:
wiring/box setup - Last Post -- posted image.
aznboi3644
Gold - Posts: 2,600
Posted: May 25, 2007 at 10:17 PM / IP Logged
What coil impedances are your subs??
TYPE E subs are not dual coil subs so that wiring will not work
Those links to the subs and amps do not work either
Just post the specs of the subs and amp
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
