don`t work door lock porsche boxter.
1000toni
Member - Posts: 14
Posted: May 28, 2007 at 12:39 PM / IP Logged
hi I need its aid neither with the button nor the control works the closing of doors the opening if.
enice
Silver - Posts: 857
Posted: May 28, 2007 at 1:08 PM / IP Logged
um huh????? are you trying to say that your door switch does not work on the porshe?  First state the year and model.
1000toni
Member - Posts: 14
Posted: May 28, 2007 at 1:25 PM / IP Logged
hi, thanks are boxster s 2003
1000toni
Member - Posts: 14
Posted: May 28, 2007 at 1:29 PM / IP Logged
I must close with key the control does not close them but if abre.el arriva inner button of the estereo also opens but it does not close.
and it excuses I do not speak ingles well.
enice
Silver - Posts: 857
Posted: May 28, 2007 at 1:38 PM / IP Logged
Lock is positive trigger thru an 180 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
The alarm/door lock module is under the driver seat.  The switch could be damaged.
