2000 land rover discovery
gf
Member - Posts: 7
Posted: June 01, 2007 at 10:01 AM / IP Logged
anyone know the color codes for the fact sub amp in the rear swing door?i installed a cd player and the fact mid-tweeter amp turns on and works fine but no factory subs?? does it use a different turn on? where would the fuse be.looks like theres a few 12 gu wires going into the rear door boot
but i don,t see 12 volts there
KarTuneMan
Platinum - Posts: 7,056
Posted: June 01, 2007 at 7:15 PM / IP Logged
Amp outputs
Subwoofer 1 + ORANGE / black For left front low range speaker; changes to BLACK/ pink. (see notes for the tail door low range)
Subwoofer 1 - ORANGE / pink For left front low range speaker; changes to BLACK/ red.
Subwoofer 2 + Pink/green For right front low range speaker; changes to BLACK/ pink.
Subwoofer 2 - Pink/red
For right front low range speaker; changes to BLACK/ red.
At the speakers
Subwoofer 1 + BLACK/ pink
Subwoofer 1 - BLACK/ red
Subwoofer 2 + BLACK/ pink
Subwoofer 2 - BLACK/ red
2000 land rover discovery - Last Post -- posted image.  Available Notes
Notes
RED / brown wire at pin COO98-6 is controlled by lighting switch; the two fuses involved are fuse no. 33 of 10 amperes in fuse box in the passenger's compartment, and fuse no. 13 of 30 amperes in fuse box in the engine compartment.
There are no colours available for the headphone speakers.
Amplifier outputs for the tail door low range speaker are as follows: RED / black to pin 1, pink/black to pin 2, WHITE/ black to pin 3 and BROWN / black to pin 4.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
