compustar turbo timer
dman007
Copper - Posts: 106
Posted: June 11, 2007 at 8:32 AM / IP Logged
Does the turbo timer affect how reservation mode is set in a manual car with remote starter? 2w900fm-as
Under regular circumstances, the car locks.arms, and the engine turns off, when the drivers door is closed- this sets reservation mode.  But what happens when the turbo timer is applied?  Will the doors lock/arm and the engine continue to run for 2 mins?  Or will the doors lock/arm and engine turn off all over the 2 mins turbo timer as expired.
DTS Performance
St Petersburg, FL
dswift
Copper - Posts: 396
Posted: June 11, 2007 at 11:28 AM / IP Logged
No, when you engage your turbo timer, you will have to lock/arm your vehicle yourself. Or you can program auto relock from the option program menu. But lock it yourself. You still will be in reservation mode. if you upgrade to the pro 2w900fm-as. you get this key icon on the remote that tells you that the car is in reservation and ready to start. It also has a turbo timer run time indicator. Nasty huh. haha
"dont ground out!"
