VSS on 2000 Cavalier
joelp
Posted: February 17, 2003 at 11:57 AM / IP Logged
I am trying to figure out where the best place to connect to the vss and also what color wire I should use. Also the pulse rate I think it is 4000 pulses but not sure. Any info would be great. Thanks
the12volt
Administrator - Posts: 3,959
Posted: February 17, 2003 at 12:23 PM / IP Logged
Here ya go....
VSS Wire: Location 17 Red 80 pin connector position 16
VSS Wire Color: GREEN / WHITE
VSS Pulse: 4000
Tach Wire: Location 17 yellow 80 pin conn position 26
Tach Signal Wire Color: White
Brake Switch Positive: Orange
Brake Switch Negative: White
http://www.rostra.com/pdf/wirelocations.pdf
VSS on 2000 Cavalier - Last Post -- posted image. the12volt • Support the12volt.com
airandsound
Copper - Posts: 69
Posted: February 18, 2003 at 11:37 AM / IP Logged
You can also get that GREEN / WHITE wire on the engine side of the bulkhead connector near the brake booster.
Its the small gauge GREEN/ Wite wire.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
