1996 sonoma, wire through firewall?
fbird
Member - Posts: 7
Posted: August 29, 2007 at 6:49 PM / IP Logged
How can I get thou the firewall from the battery to the cab in a 1996 Sonoma / S-10.
Want to use one 4 or 8 ga. for thee amps. 2 small and one not so small.
fbird
Member - Posts: 7
Posted: August 29, 2007 at 7:11 PM / IP Logged
How should I get thou the firewall from the battery to the inside of the cab of a 1996 Sonoma / S-10?
It will be 4 or 8 ga for three amps. Two small Rockfords and one not so small.
Anyone?
sarcomax
Copper - Posts: 276
Posted: August 30, 2007 at 11:14 AM / IP Logged
Automatic or manual transmission? If it is automatic, there is usually an open space where the manufacture would have routed the clutch cable. I have not done one of those in a while, so I don't know of the best place off the top of my head. If you don't see a good place, and you are not 100% sure that you won't nick a wire, cable, or brake booster, then spend a little cash at your local install bay and save the money of replacing a wire loom or brake booster.
dirtjumper895
Member - Posts: 24
Posted: August 30, 2007 at 3:50 PM / IP Logged
You should be able to find a factory grommet through the firewall in the passanger floorboard... It is for the antenna for the radio's wire.. I snuck my 4ga wire in that grommet with the antenna wire... it find it pull back the pass side carpet in the front, you'll see it... it pops out kinda underneath about 1.5 ft below the blower motor... Good Luck!!
