starter will not disengage
e2lancer
Posted: September 01, 2007 at 4:24 AM / IP Logged
installing a ProStart 3300 in a  2001 Evolution7 lancer, remote start works but every 5sec the starter will engage and it grinds badly. will connecting the tach wire fix it? can anyone tell me the location/color of the tach wire for an Evo7? Thanx.
Platinum - Posts: 13,726
Posted: September 01, 2007 at 7:34 AM / IP Logged
Yes, if you connect the tach wire, the remote start module will know the engine is running.  Armed with this information it will not continue trying to start.
audioman2007
Copper - Posts: 580
Posted: September 01, 2007 at 8:40 AM / IP Logged
Thats correct. The tac wire must be installed properly. That wire will sense when the engine has started by sensing a change in RPM's once started. Then tells the remote start to to stop.
profuse007
Gold - Posts: 2,015
Posted: September 01, 2007 at 9:46 AM / IP Logged
Tachometer   GREEN/ silver dots    wht plug behind clocks
Houston,TX
e2lancer
Posted: September 01, 2007 at 10:55 AM / IP Logged
very thankful for your quick response, will do as required.
manuy thanx.
griselda
Member - Posts: 41
Posted: September 01, 2007 at 3:41 PM / IP Logged
tachometer wire is GREEN/ silver dots ............wht plug behing clock
e2lancer
Posted: September 03, 2007 at 4:33 PM / IP Logged
have had no success. found the white plugs behind clock but only light green w/silver dots there are4 all identical - no green w/silver dots . are these the wires you reffer to? we used a multimeter on ac volts but it did not fluctuate. do i have any other option for a tach wire?
thanx.
wrenches
Member - Posts: 44
Posted: September 05, 2007 at 10:09 AM / IP Logged
You can use either -ve of fuel injector, or -ve off of a coil.  Sorry, I don't have wire colours, but you did say you had a meter that would read AC so it sounds like you should be okay.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 05, 2007 at 10:28 AM / IP Logged
Hers what Astro has. grn/wht @ the PCM, OR  blk/lt.grn, or blk/yell. @ the coils, or the pcm.
Seems to be ALOT of choices here..... somthins gota work?
e2lancer
Posted: September 06, 2007 at 4:47 PM / IP Logged
Hi KarTuneMan, could you please tell me the location of the PCM and would we need to use a diode protected meter?
Thanx.
