2001 tacoma 712t wiring
cu52
Member - Posts: 27
Posted: September 14, 2007 at 3:56 PM / IP Logged
Hello,
I have a 2001 ext cab Tacoma I wanted to see if there is any guide or specific assistance for the install of a 712T in my truck. I have the diagrams for all of the wires and locations needed to connect to. I do not know if i need any additional relays or if I can connect all of the items directly.
Any Ideas?
Lock / Unlock
Horn output
Parking Light Flash
(I think my domelight is controlled by the truck no need to connect this).
Thanks a lot for the assistance.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 15, 2007 at 10:03 AM / IP Logged
Thats a cool little unit...   You should NOT need any other relays or parts.
Program for double pulse on unlock.
Myself, I would not connect the horn output... HONK EVERY time you lock and unlock, and it won't be a soft little honk either!
cu52
Member - Posts: 27
Posted: September 15, 2007 at 5:34 PM / IP Logged
I have all hooked up except for the door locks (Most important part eh?). Which do I need to hook into?
       POWER LOCK|gray *1             |- |white plug near fusebox     |
|     POWER UNLOCK|purple *1           |- |white plug near fusebox     |
|       LOCK MOTOR|blue/white          |   |DKP, 12 pin plug in pin 10 |
|     UNLOCK MOTOR|blue |   |DKP, 12 pin plug in pin 11 |
Also the Blue and blue with white are in a 13 pin i think it looks like this. I found the gray on the side of the fuse box (coming out of the white plug. Please help with which wire goes to what on the vehicle and the alarm. thanks.
bwxxxxxx
xxx   xx
cu52
Member - Posts: 27
Posted: September 15, 2007 at 7:58 PM / IP Logged
Nevermind I have it all figured out. Horn only honks if you press the lock button twice. system works good. Only complaint would be the long pause for the double pulse on the unlock.
