2 subs compared to 4 subs
2fas4ya
Member - Posts: 19
Posted: September 21, 2007 at 1:48 PM / IP Logged
Is there any disadvantages in running 4 subs compared to 2 subs to achieve the same overall RMS? As in like 2 12" subs with about 700 rms each compared to 4 12" subs with around 350 rms a piece. Would be connected to a 1500rms.1 amp wired up either way to achieve a 2ohm load. Would they sound about the same and just be taking up more space? Also is there anything wrong with running 4 of the same subs in 2 different type boxes? As in 1 bandpass/1 sealed or 1 sealed/1 ported or would all in same type box work best?
DYohn
Platinum - Posts: 10,741
Posted: September 21, 2007 at 3:38 PM / IP Logged
4 woofers with the same total power = 2 woofers +3db.  4 woofers with twice the total power = 2 woofers +6db.  This assumes the same types of woofers in the same kinds of enclosures.
aznboi3644
Gold - Posts: 2,600
Posted: September 21, 2007 at 11:30 PM / IP Logged
also with 4 woofers of the same kinda vs the 2 woofers, less power compression
jl.w7
Copper - Posts: 59
Posted: September 23, 2007 at 5:43 PM / IP Logged
4 would definately give you more surface area and alot better spl
MECP Certified
(2)Infinity 3.5" 3012CF
(2)Infinity 6x9 9612I
(1)Sony CDXGT710
(2)MTX TC510 and,
A load of dynamat!
1982 Chevy Cavalier
zacdavis
Member - Posts: 30
Posted: September 23, 2007 at 10:23 PM / IP Logged
I would recommend sticking with an enclosure/s that has equal volume and tuning for each sub.
