Pro Start 3300 Orane wire 10 pin connect
bt3668
Member - Posts: 13
Posted: February 21, 2003 at 5:03 PM / IP Logged
I am a little confused about the connection of this one wire. I have a 1997 Pontiac Grand Am. Is there a particular wire i should look for to connect this too? or just any negative wire? Any help will be much appreciatedPro Start 3300 Orane wire 10 pin connect - Last Post -- posted image.
jrilla
Gold - Posts: 1,498
Posted: February 21, 2003 at 5:40 PM / IP Logged
I think that is the ground out when running wire? or when armed? I am not sure but that is what you use to trigger the starter kill relay if I am thinking about it right. If you have a three wire relay harness it should go to the orange wire and then the Red would go to the starter wire key side and white goes to the engine side of the starter wire along with the starter wire output from the 3300.
J Rilla
Owner/Installer
bt3668
Member - Posts: 13
Negative Ground  when armed and starting/running output. unsure of where this needs to be connected
Platinum - Posts: 12,488
Posted: February 21, 2003 at 7:05 PM / IP Logged
The 3300 diagram that I have shows a P12 harness... not a P10 harness ? The ORANGE wire is the (-) parking light wire output.
12voltlover
Member - Posts: 16
Posted: February 23, 2003 at 2:11 PM / IP Logged
the orange wire on the 3300 is ground when running and when armed. you will need it for passlock bypass on your grand am. i think the 97 grand am used passlock 1 so i would recommend a dei 555L.
