relay, starter kill relay
xavier213
Member - Posts: 15
Posted: November 26, 2007 at 9:18 PM / IP Logged
I know with some car alarms if you unplug the main power the starter kill relay will default and you can start you car… I am thinking of wiring the a relay in line with the power wire to the (OEM) main relay and if the alarm was unplugged the relay would go to default (I think 87a) but would not be powered up because the main relay would be hooked to 87…  so I think the relay needs to stayed powered up when the car is on and powered off when the car is off…. But I don’t really know how I would hook this all up or if it will even work..
sorry if i confused any one..
techman93
Silver - Posts: 591
Posted: November 26, 2007 at 11:19 PM / IP Logged
https://www.the12volt.com/relays/page2.asp
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
