valet 561r?
rkreimer10
Posted: December 11, 2007 at 1:32 PM / IP Logged
ok this is my first time installing a remote start and i pretty much understand everything except a few things. the car is a 91 dodge shadow with no power options so i will be using very few wires from the kit, well here are my uncertainties.
1.) i want to use the rear defroster option i know that it uses the blue/white wire on the 5 pin connector. but what color wire behind the dash do i splice into? i cant find it on the wiring diagram for the car. i tried searching for hours last night.
2.) i want to hook up the anti grind option. i know this uses the blue wire from the 4 pin satellite, but do i need to ad my own relay? or do i just splice into wires that are already in the car?
thank you for any advice in advance. when im done making my personal diagram i will post it to make sure everything is correct.
ryan
chriswallace187
Gold - Posts: 1,661
Posted: December 11, 2007 at 2:50 PM / IP Logged
Ryan,
1. For the rear defogger you will need to meter the wires at the defogger switch to find which one you need. I have yet to ever see remote start install information include wire colors for this because not many rs units have the capability.
Basically you'll have 3 distinct possibilities.
  1. A wire from the switch that goes to ground only when the switch is held in
  2. A wire from the switch that stays at ground the entire time the defogger is active
  3. A switch with a timer built into it which has 2 heavy gauge wires, one of which directly powers the defogger grid
99% of the car's I've done defoggers on have been one of those 3...it's really not too hard to hookup at all once you figure what you're working with - feel free to PM me for more help here if you want.
2. To do anti-grind you need to cut the starter wire in the ignition harness and hook up a relay as follows:
87 - key side of cut starter wire
30 - starter side of cut starter wire(also you'll need to hook up the purple starter output from the 561R on this side or the 561R won't work)
85 - blue (-) status output wire in 4-pin harness
86 - 12v+ constant
C Renner's Auto Electronix
