giordan car alarm remote start g686 s
jaychris0708
Member - Posts: 10
Posted: February 27, 2009 at 8:28 AM / IP Logged
Hey All,
Just wanted to get some help on my remote start system it won't start...... i think the problem is that it said in the manual it has a brown wire on the relay but there's none but instead its white..... i don't whats happening but when i press the bell button to start it it won't start it just does the crank noise can some some one help me please?????
Posted: February 27, 2009 at 5:17 PM / IP Logged
What vehicle, might you have a factory transponder that hasn't been by-passed?
jaychris0708
Member - Posts: 10
Posted: February 27, 2009 at 6:52 PM / IP Logged
i have a 2003 mitsubishi lancer vrx ch
Posted: February 28, 2009 at 3:43 AM / IP Logged
Try it with the key in the ignition, if it starts you haven't by-passed the transponder.
jaychris0708
Member - Posts: 10
Posted: February 28, 2009 at 10:53 PM / IP Logged
nah i tried that and its still doesn't wana turn on with the remote, well my friend said that we done it right but it says in the manual hook a brown wire which it didn't have a brown wire, it had the white wire....... cause when i try to turn it on it clicks but it doesnt turn on it goes back to off.....
Posted: March 01, 2009 at 2:49 AM / IP Logged
Stop panicking and tell me is this brown or white wire from the alarm or from the car and what's it's function?  If it's the wrong colour have you tested it to see if it's the right function?  What actually happens when you try it, do the ign lights come on?  Test all it's functions, I've no idea what a giordan alarm is, never heard of them.  Any technical back-up in Strine or NZ because if there isn't you're shafted.  I'm still betting on a missing ign wire, transponder or tach.
jaychris0708
Member - Posts: 10
Posted: March 01, 2009 at 2:44 PM / IP Logged
well in the diagram it suppose to be white from the alarm to the relay and then brown from relay from to the cylinder on..... but instead it's all white instead of white and brown...... and yes the light ingnition come on and off when i try to start with the remote so we don't know if that is right.
Posted: March 01, 2009 at 4:16 PM / IP Logged
What's the relay a starter kill?
jaychris0708
Member - Posts: 10
Posted: March 01, 2009 at 4:34 PM / IP Logged
yep
Posted: March 01, 2009 at 5:57 PM / IP Logged
Don't use it,  check the tach, ie have you programmed it correctly?  If it cranks and you get the ignition lights on you've basicly done every thing, have you wired up ALL the outputs from the ignition switch? I'm still about not sure about it not starting even when the key is in the ignition, I have a 2000 Galant which has a transponder, I've done loads of Evos also with transponders, I was sure that a 2003 especially if New Zealand uses Aussie rules would have had a transponder immobiliser.
