Wireing My Amp and subs
victor_26086
Posted: March 10, 2004 at 11:36 PM / IP Logged
i have a 4000 watt mobil authority amp and 2 12" solobaric kikkers L7 the speakers can be 2 or 4 OHms how and amp is
                 1 Typical Current Draw At IDLE: 1.4Amps 4 Ohms: 2 x 400W 2 Ohms: 2 x 700W 1 Ohms: 2 x 1200W 0.5 Ohms: 2 x 2000W Mono: 1 x 4000W
and the woofers:
Impedance........2 Ohms
Max Recommended Amplifier Power ..........1500 watts peak
Max Recommended Amplifier Power ...........750 watts RMS
QUESTION: how should i wire this?
Ravendarat
Platinum - Posts: 2,806
Posted: March 11, 2004 at 1:35 AM / IP Logged
If this is a 2 channel amp rated to run down to half ohm than just wire everything in parrell and bridge the amp. So you just connect all the positives off all the subs to one channel and all the negatives off all the subs to the other channel. According to your spec you should be getting about 700 watts rms per sub.
