no crank
shaunis
Member - Posts: 6
Posted: November 14, 2004 at 2:00 PM / IP Logged
Hey all,
I recently installed a mannix sm700 on my car. The remote start has a feature where you have to set it before you get out the car the previous time. I did this and it wouldn't remote start, but that's not the problem. My car wouldn't crank period even with the key in the ignition. When i turn the key to the start position i don't even here a click. I've disconnected the alarm and everything, and i metered all the ignition and start wires and they are fine. Even without the alarm connected my car won't crank. Any ideas what to do next?
P.S. i also checked all the fuses in the car and under the hood.
draasch
Gold - Posts: 2,172
Posted: November 14, 2004 at 2:19 PM / IP Logged
what kind of car do you have???????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
shaunis
Member - Posts: 6
Posted: November 14, 2004 at 3:28 PM / IP Logged
sorry..thought i wrote that in. Hyundai accent 2001 1.5L
jrilla
Gold - Posts: 1,498
Posted: November 14, 2004 at 3:54 PM / IP Logged
Did you cut the starter wire at any point in the install, like to put in a starter kill relay? Is this a manual transmission vehicle?
J Rilla
Owner/Installer
shaunis
Member - Posts: 6
Posted: November 14, 2004 at 4:18 PM / IP Logged
yes i did cut the start wire to put in a relay, but i reconnected it back when i took out the alarm. Also this is a manual.
Platinum - Posts: 12,488
Posted: November 14, 2004 at 5:56 PM / IP Logged
Boy, sounds like something I just help out with last night for a member here. What happended was the starter relay burned out and wasn't giving the starter solenoid any power. Find the starter wire and meter for power first, if not power is there, then it's your relay that is pooched.
metaverse
Copper - Posts: 210
Posted: November 14, 2004 at 8:50 PM / IP Logged
"yes i did cut the start wire to put in a relay, but i reconnected it back when i took out the alarm. Also this is a manual."
Manual as in a manual transmission ? Did you check into a clutch bypass ?
jrilla
Gold - Posts: 1,498
Posted: November 14, 2004 at 10:43 PM / IP Logged
Yeah metaverse asked my next question. I asked if you had a manual transmission vehicle because you would have to bypass the clutch and either you did not bypass the clutch and so the RS didn't work, but then if you tried to start the car with the key, we all know you wouldn,t forget to put the clutch in. So that leaves us with the attempted but possibly failed clutch bypass. Either that or what Jeff said.
J Rilla
Owner/Installer
shaunis
Member - Posts: 6
Posted: November 15, 2004 at 6:20 AM / IP Logged
I actually had not bypassed the clutch yet, i was waiting to get everything working. What i did was just tape the engage button down on the clutch, so i was able to start the car without pressing the clutch in. Also i metered the starter wire at the ignition, and its getting power. Gonna try to find the wire down at the starter motor and see if there's power.
metaverse
Copper - Posts: 210
Posted: November 15, 2004 at 9:03 AM / IP Logged
I was about to ask how the clutch switch works until i found this link
So, looks like you have a different problem to begin with..Good luck troubleshooting
