Remote car starter Help!!!
dnastyboy1
Member - Posts: 12
Posted: October 15, 2002 at 4:55 AM / IP Logged
I need help on how to hook up my remote car starter. I have this http://www.ultrastarters.com/Html/2250.html model and I had it installed already but the installer guy said that he need some questions to the technical support but It's been almost 2weeks already and I haven't hear from him yet. He installed the system(alarm/CPU)but he didn't hook up the remote start. My question is can I do it myself? How? Can anybody help me with this 'cause I want it to be hooked up already. I got a 1993 Acura VIgor GS(Manual Transmission). I'm using just the alarm right now and the door lock & unlock.
Anthony
1994 Acura Legend GS
1993 Acura Vigor GS
Platinum - Posts: 12,488
Posted: October 15, 2002 at 5:30 AM / IP Logged
The problem is that he put the wrong unit into your vehicle Remote car starter Help!!! -- posted image.. You should have gooten the 2250M ( unless that is the unit that the installer got you ?? ) If so then to do the starter is simple. You only have about 4-5 more wires to hook up and your done + programming. Here are the wires that you still need to hook up:
  • |          STARTER|BLACK/ white         |+  |ignition harness            |
  • |  SECOND IGNITION|yellow              |+  |ignition harness            |
    |        ACCESSORY|WHITE/ black *1      |+  |ignition harness            |
    |        HOOD PIN|yellow/red          |-  |theft module *4             |
    |FCTRY ALRM DISARM|GREEN/ black         |-  |lrg harness left of fuse box|
    |       TACHOMETER|blue                |   |ignition coil or *2         |
    |       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
  • * 2 The tach test connector is located on the right side of the engine compartment.    *4 The anti theft module is located behind the glove box behind all other modules closest to the fire wall.
dnastyboy1
Member - Posts: 12
Posted: October 16, 2002 at 3:56 AM / IP Logged
Thanks a lot Jeff
Anthony
1993 Acura Vigor GS
Mobile Ins
Member - Posts: 6
Posted: October 16, 2002 at 9:56 PM / IP Logged
You need to by Pass Clutch too and it's not good to  instaling starter in Manual Transmission if it's not design for that..jeff right You should have gooten the 2250M ...remember after instaling that you have to make sure before you leave..... car not in gear..Otherwise you will find your car in someone home or on Highway [;)]
Mobile Installer
dnastyboy1
Member - Posts: 12
Posted: October 17, 2002 at 4:18 PM / IP Logged
Jeff,
  Can you tell me where can I find the Neutral Safety Switch of my car?
Anthony
1993 Acura Vigor GS
dnastyboy1
Member - Posts: 12
Posted: October 17, 2002 at 4:20 PM / IP Logged
Yes, I got the one for manual transmission which is the 2250M series.
Anthony
1993 Acura Vigor GS
