Remote starter installation Ford explorer 2002
verbal7
Posted: November 15, 2002 at 9:17 PM / IP Logged
Remote strater = Impulse RES FCCID JLFU1
I have the wiring diagram of the SUV and the module but I have a few Q before I strat the installation. I downloaded the wire diagram from this site for the Explorer and the module.
https://www.the12volt.com/installbay/display_topic_threads.asp?ForumID=1&TopicID=3278 FORD EXPLORER
https://www.the12volt.com/downloads/file.asp?ID=278 IMPULSE RES
Now I need somebodys help to get the wires together:
Here we go:
MODULE
CONNECT TO
FORD EXPLORER 2002
LOCATION
RED
CONNECT TO SRTONG SOURCE.
12v / YELLOW ??
IGNITION HARNESS
YELLOW
CONNECT TO TRUE IGNITION. THIS IS THE SYSTEM IGNITION OUTPUT ASSURE THAT THIS WIRE REMAINS ON DURING CRANKING
IGNITION  RED / LT. GREEN ???
IGNITION HARNESS
YELLOW / RED
ACCESSORIES OUTPUT. THIS IS THE OUTPUT WHICH WILL POWER THE HEATER AND AIR CONDITIONER SYSTEM DURING REMOTE START
ACCESSORY GREEN/ LT GRENN ????
IGNITION HARNESS
PINK
+ START INITATE INPUT
STARTER RED ???
IGNITION HARNESS
ORANGE / WHITE
CRANK OUTPUT THIS IS THE OUTPUT THAT CRANKS THE STARTER DURING THE REMOTE START ALSO USED FOR STARTER BYPASS
BLACK ON 14 PIN HEADER
CONNECT TO LOW IMPENDANCE GROUNG A CLEAN CONNECTION IS  A MUST
I GUESS TO THE BATTERY GROUND???
WHITE / GREEN
ALARMS SHOCK SENSOR BYPASS INPUT CONNECT TO ALARM SHOCK SENSOR OUTPUT
??? IN WHAT???
WHITE  / RED
ALARMS SHOCK SENSOR BYPASS OUTPUT CONNECT TO ALARM SHOCK SENSOR INPUT
??? ALARM ???
ORANGE
INGNITION BYPASS OUTPUT. CONNECT TO IGNITION INPUT OR AFTER MARKET ALARM. THIS WIRE FOLLOWS THE IGNITION OF THE CAR, EXCEPT WHEN SYSTEM IS IN START MODE
???HUMM???
YELLOW / BLACK NEW 15 AMP 2ND IGNITION OUTPUT
15A 2ND IGNITION OUTPUT
??? WHAT???
GREEN
(-) DOOR CONNECTION
GROUND ???
PURPLE
(+) DOOR INPUT
DOOR TRIGGER  BLACK / LT BLUE ???
DRIVER KICK PANEL
BLUE
(-) START INITIATE INPUT
??? ANOTHER ONE???
PINK / BLACK
BREAK PEDAL(+) INPUT. DISCONTINUES REMOTE START WHEN PRESSED
BRAKE WIRE TAN /RED TO LT.GREEN
BRAKE PEDAL SWITCH
WHITE / BLACK
OPTIONAL (-) COIL TACH INPUT. DO NOT CONNECT UNLESS THE REMOTE START FAILS TO RETRY IF THE FIRST CRANK ATTEMPT FAILS. CONNECTS TO THE (-) OF THE COLI KEEP AWAY FROM HIGH VOLTAGE WIRES IF USED SET WITH SW5 TO OFF
I THINK THE TACHOMETER ???
IGNITION COIL/PACK DO NOT USE WHITE / LT.BLUE
PURPLUE / WHITE
THIS IS A MULTI FUNCTION OUTPUT: IF SW3 = ON THIS IS A SECONDARY (-) CRANK OUTPUT. CAN BE USED FOR PATS OR OTHER BYPASS FUNCTIONS
IF SW3 = OFF THIS OUTPUT ACTS AS A FACTORY REARM OUTPUT ( THE OUTPUT WILL PULSE ONE TIME AFTER THE CAR HAS STARTED VIA REMOTE)
??? IN ENGLISH PLEASE???
BROWN
ACTIVE (-) USED FOR BYPASSING FACTORY ALARMS
??? WHATEVER???
WHITE
PARKING LIGHTS OUTPUT (12V+ 15Aa UP TO 50A INRUSH) CONNECT TO ONE OF THE PARKING LIGHTS OF THE CAR
PARKING LIGHTS + BROWN
HEADLIGHT SW OR DRIVER KICK.
Please help to fill the blanks and use the table for future reference...
I live in NM in the middle of nowhere and I want to do this by myself, proud I guess... THANKS
JR
Platinum - Posts: 12,488
Posted: November 15, 2002 at 10:47 PM / IP Logged
